Im at the stage off renewing the interior arcitrave,skirting,plaster,wiring on my old cottage/barn. The previous owner some 13 years ago had damp proof injected into the walls and re-plastered upto a metre, this is off a pink finishing plaster and greyish- white plaster beneath, is this lime ? how do you tell the differance ?
There is about 5 % of the building which is showing damp.
The solid 215mm red brick wall is off lime mortar.
I would like to have some internal insulation, ive been told to remove all plaster, paint `kingfisher` SBR on walls, install 25mm insulation between battons, plastic sheet and then plasterboard ?
Or should I leave the walls as they are and just deal with the 5 % damp ?
sorry for lots of questions , but any advice will be great.
Colin
Colin
