overlander matt
The floor boards are up in two rooms and the heating pipework and new cables are nearly in. I would like to insulate between the floor joists but can see a couple of different approaches will be needed. In one room the floor joists are reasonably new 6" timber and an insulation board could be used but in the other they are very old with irregular shapes and spacings. I wondered whether an roll-based insulation material might work better in this case. In a previous house, I used chicken wire to support the insulation material but did not use any membrane which might well have been a mistake...
What would be a suitable membrane to use and is it best installed above or below the insulation? Any suggestions would be very welcome.
Thanks.
Thanks.
