Dear Forum,
I have a grade 2 listed farmhouse with 2 attic rooms that had all the ceiling plaster removed (lathe and plaster + some plasterboard). The oak beams are in a bad state, loads of worm decay etc, but no signs of wet or dry rot, which I have in other areas of the house.
I have spent ages (2months) sanding down the beams so that these will now be shown rather than just plastering over it all. My concern is that between the beams I have placed a thin 25mm layer of celotex board, behind which is old roofing felt (non breathable) and used small battens 1 1/4 inch either side of the rafters in order to apply plasterboard, which I have started to plaster over.
I now have a visit booked by the council, but have read so many different things lately about using lathe + lime mortar etc to let the building breathe, so concerned now that what I have done is either not going to be exceptable by the council or could cause issues with condensation etc.
There is still air flowing between the roofing felt and insulation, not a great deal as this is mainly from a gap where the attic rafters meets the brick wall.
The effect I'm trying to achieve is to expose the oak beams rafters that have now be cleaned up, whilst trying to have some insulation. Any thoughts on how this can be achieved with a minimal gap between roofing felt and rafters (2 - 4 inches thick) or if anyone else has used celotex in an old building roof without issues please let me know.
