malcolm
& Clementine the cat
- Bedfordshire
I need to make a decision about insulation and I can't decide what to do with the north gable wall in the photo below.
The construction is interesting. You can see the impression of the original 17th century timber framed building. The timber has been infilled with 9 inch brick up to first floor level, then infilled with 4 inch brick to the roof and rendered. The 19th century extension is in 9 inch solid brick and is not tied to the timber frame. There is plenty of damp in the wall which will hopefully be improved by lowering the ground level, removing the failing paint, and re-pointing.
I want to do what is best for the building. Although building regs want me to propose some upgrade to the insulation because the house is going through a change of use and because I want to strip modern plaster from the kitchen (in the extended part).
One option is to add internal insulation to the kitchen (breathable of course). Possibly wood fibreboard with lime render. My concern with that is a likely increase in wall damp. I can probably negotiate a lower u value than building regs would normally want.
Another option is to add external insulation to the whole gable. Again wood fibreboard and lime render. The advantage would be the timber frame stays warm and hopefully less damp. The disadvantage is the roof tiles are not secure enough to be extended so I'd be looking at a new roof as well. Also this would remove some features from the gable.
A third option is to leave the whole thing alone and argue with building regs.
What would you do with this wall?
