Van Bergan
- Kent
Hi all,
I have spent the better part of a day trying to decide the correct spec to insulate the GF suspended timber floors of my victorian semi-d which over lay my cellar.
Unfortunately, like most building renovation details there is seemingly no build-up which all agree is correct.
Two major points of contention are:
I find doing the work is the easy part of period renovation; getting the design fixed the harder part by far.
I would appreciate to hear your take on the matter!
- Promotion for or against a VCL:
- Some recommend using a VCL for the usual wise reason of halting the transmission of warm moist air into the floor unit from the habitable room above.
However when you think about this it doesn't really make sense as the cellar will almost certainly be more humid than the room above. Furthermore the VCL may even hinder evaporation of moisture in tight areas such as joist ends.
- Insulation type selection
- Some say that PIR is sufficient;
- others say that PIR being non-breathable should not be used and that mineral wool should instead be used
- others then say that mineral being non-hydroscopic should not be used, and that a natural fibre insulation should instead be used
- then others contend that ground floors should not be insulated at all! (which @Toby Newell in a previous post actually makes a good case for).
