Hi,
New member so be gentle.
I have a semit detached villa built in whinstone, walls about 800mm thick( i know this be3cause it took 15 hrs to core a hole for the boiler flue).
Renovating house 1 room at a time.
Now in Lounge, bay window beyond repair(house empty for years) dry rot wet rot woodworm mice .
Getting new timber sash and case windows made by local joiner,below window is cladding to the floor, i was sanding the floor and paying more attention to the construction i noted that this cladding would have to come off for the windows to come out and then replace cladding.
I am handy with the tools so i carefully removed cladding( found wood worm, and sprayed all wood in area.
Now Behind the cladding is the stone walls, would it be possible to fit insulation to this wall directly or is a gap required.
from wall to rear of cladding 50mm max.
Best Regards
Tony
Best Regards
Tony
