HelenS
- Corley, Coventry
Hi there,
I have just joined and this is my first post, also very "new " to old buildings so please forgive my lack of knowledge, but I am very keen to learn.
We live in a house that was built approx 1650 (it actually appears on an old map). It was originally a timber frame with pink sandstone at the bottom and has had later additions. We bought our house about 2 years ago because we loved it so much, not understanding that the cement and stone render on the outside or the spray foam insulation in the loft, wet cellar etc etc could such an expensive nightmare to sort out. It is not listed. This beautiful house is like a naughty school child and keeps missbehaving.
We, like many others, are on a tight to non existent budget. This means that we have to put right what is going wrong at the time rather than start with a logical plan.
After a leak in one of the uppstairs bathrooms we decided to "gut" it and start again. We removed 3 layers of floorboards, riddled with wood worm holes, so called in a company to spray the very large, uneven joists that are left. We uncovered the original wall behind plaster board but unfortunately the timber frame has also been attacked and the lath and plaster cover to the bricks is in very poor shape.
I found a contractor who works with lime and he will sort out the loose mortar on the internal brickwork.
After all of that waffle my question is how best to insulate the 2 external walls and sloping ceiling. The more investigating and research I do the more I become confused. I have been advised to leave a 25ml air gap, then errect a metal frame work and apply 100ml of sheeps wool (I have already bought this), then apply a moisture check plaster board and normal gypsom plaster. I will also fit an extractor fan I realise that I will need to remove the outside render but, due to lack of funds, won't be for a while.
Does this sound like a sensible way to do the insulating?
Thank you in anticipation xxx
