Geoff Flegg
Yet another insulation question........
My house is a Victorian three-storey affair, with attic rooms with sloping ceilings - so we have no loft as such. We re-roofed the house recently, and took the opportunity to fit insulation - although it is a pig of house to insulate!
The floor area of the attic rooms is less than the floor below, as you have the area around the edge of the building where the headroom tapers to nothing - the eaves space - which has lightweight lath & plaster walls blocking it off from the attic rooms.
The insulation is generally in between the attic ceilings and the rafters, but we have eaves space which is accessible and is used for storage. Despite using breathable roofing membrane, the Building Inspector insisted on vent tiles being fitted for all the enclosed spaces in our roof - of which there are plenty. This means we have a minor gale blowing into the eaves space, and cannot insulate these spaces at rafter level.
The eaves space being uninsulated is not a problem as such, as it's only for storage, much as a loft. The question is though is that we are losing heat from the bedrooms underneath. I can solve this in one of two ways:-
1 - Take up the floorboards in the eaves space and stuff ordinary loft insulation / thermafleece in between the joists. Will help, but given the depth and the cold bridge effect of the joists it could be better. Floorboards will also be a pain to lift.
2 - fix Kingspan / Celotex slabs over the floorboards, and put some cheap chipboard flooring over that to spread the load for me crawling about and for all the junk I keep in there. Will insulate extremely well, better than option 1, but am I asking for problems with condensation forming on the underside, affecting the floorboards / joists ?
Anyone got any better ideas?
Geoff
Geoff
