kkliskey
- Oxfordshire
Hi everyone. We are in the middle of decorating our ground floor living/dining room in a victorian house. What was meant to take a month or two has now taken us 3 months and we are still no where near finished
We have got to the stage where we are working on the floor. The carpet was ripped up a while ago with the intention of having exposed floor boards. The majority of the floor boards are sound and those that aren't will be replaced with reclaimed boards which have already been bought and are aclimatising in the same room. We have read about incorporating insulation under the floor boards which we have decied we would like to do. Now this is where we don't really know what we are doing and my many questions start....
1. Is there an easy way of lifting the floor boards with out spliting the wood. This has happened to a couple of the boards that we have lifted and we don't want to have to replace the lot.
2. I have read that you can use loft insulation secured with nylon garden netting. Can this loft insulation be the space blanket type that is encased in foil and plastic sheets?
3. Does the netting run above the joists or does it need to be fixed to the underside of the joists. I've read that both are possible but not sure what standard practice is.
4. We have a number of pipes (gas and water) and electrics running under the floor boards. Most are level with the bottom of the joist but some are higher up. I worry that if the insulation is in contact with these pipes/cables it might cause a fire hazard.
I think that's it for now but I'm sure I can think of more later :? After I ask myself all these questions and try and work out the answers, I wonder if its all worth it. Will the insulation make that much difference?
Looking forward to any advice. Many thanks, Karolina
