Geoff Flegg
Just in the final stages of buying a Victorian semi, which needs a new roof covering.
As the roof is being re-covered, the job needs Building Control approval from the local authority - who tell me that you now have to get the roof up to 0.2 u-value.
Problem is, the house was built from new with attic rooms, so there are (perfectly good) lath and plaster ceilings attached to the bottom of the rafters.
Stripping the roof obviously gives the chance to introduce insulation - there's none at all at the moment. You only have the rafter depth to use though - 4" - and 1" of that needs to be left empty under the (new) breathable-type roofing membrane. To insulate right up under the membrane would involve using counter-battens under the roof tiles, which I can't do as that would make my roof higher than my neighbours (remember it's a semi ! )
Using the likes of Celotex or similar, I can't get the u-value I need with only 75mm to play with. Which means having to strip the ceilings out, insulate underneath the rafters as well as between, then plasterboard and skim to get a new ceiling. This also reduces the (already not great) headroom.
Anyone got any bright ideas on this one? I've considered the "superquilt" insulation from YBS (http://www.ybsinsulation.com) but hear mixed reports on it's effectiveness, plus you are supposed to use it running across underneath the rafters with a vapour barrier etc, not between the rafters with no vapour barrier.
It just seems such a shame to destroy perfectly good ceilings!
