BarumMike
 - North Devon
My daughter and son in law live in a house assembled from two small brick built cottages plus add-ons.  One room is the ground floor of one of the cottages complete with front door.  This is no longer in use but contributes to making the room perishingly cold.  It is amodern but low spec door with a pair of glazed panels.  How to insulate this while preserving the external appearance of the property in its pretty Chilterns village?  And ideally also preserving the contribution to the natural light in this relatively dark room.  They are planning to internally insulate the solid external wall with a wood fibre plaster system.
They are not keen on the nuclear option of bricking up the doorway. So
1. leave the current door in place and seal it off internally with some form of insulated internal wall (and window)?
2. replace the current door with a custom made false fixed door with appropriate insulation spec?
3. replace the door with an off the shelf high spec door, triple glazed etc?
4. put in an internal second ?double glazed door
5. or just accept its too difficult and use sealant between door and frame and put a thick curtain in the recess
anyone faced a similar problem?
