Hi
I am looking at options for insulation for a grade II C18 timber frame cottage. The stud posts are 4" deep and batons for the plasterboard are installed at 1" from the interior face of the frame. The beams are exposed internally, but rendered over externally. I have ripped out the insulation and plasterboard in our downstairs shower room and started making enquiries with our conservation officer about whether to remove the external cement render and re-plaster in lime.
I have looked at some insulation options online, the conservation officer mentioned wood fibre and I've also looked at hemp and wool options. I've been checking out the spec for plastering and think I need circa 1) A haired scratch coat (12-15mm) and then 2) An unhaired float coat (8-10mm) the lime plaster will sit on laths 6mm? ( not sure which I should use oak, larch, chestnut / riven,sawn...?) So that means I need to move the batons back a bit (6mm) and that will leave at best 60mm for insulation. However the external render is quite lumpy so I might not have 60mm everywhere.
Has anyone else insulated a similar building and depth of stud - what did you use and how did it work out?
