jungle_jim01
- Loftus, North Yorkshire
here's one forthe builder's amongst you. I have a small cottage style window approx 40cm width. The lintel stone above doesn't appear to be sat on anything other than being mortared to the surrounding stones and window frame. Obviously the ideal would be to pull the whole lot out and reinforce somehow but it's a job to far at the moment. It's obviously been in there quite a long time as the window appears to be fairly old. And there's no obvious signs of movement. So is it possible that just the mortar is holding it in place? or could there be some kind of internal support that i can't see. Has anyone had any similar issues?
This has come about as i'm re-pointing (still!) and unsure whether to remove the cement pointing around this lintel...hmmm...the adventurer in me says there's only one way to find out...don't really fancy that approach this time though!
