plasticpigeon
- Birmingham
Hello. I have been doing up some sash windows recently and am looking for some advice on how to best fix sash windows in position. In my house the windows were built in, the arches brick being built onto the top of the window frame (which has bricks forming an arch behind the arch filler. They are also fixed into position by mortaring round the horns. this seems a poor way of fixing the windows in, and means that the springer bricks on on either side of the brick arch only exist on the outer skin and the inner side of the arch is not really supported (once the mortar has crumbled and the house has moved a cm or 2!!!) In one book I have it talks of building wooden bricks into the brick jambs in the inside or hammering in wooden wedges and then skew nailing the window into its recess through the inner and back linings. Is this a good or the best method? It seems to me a better method would be to make the inner linings wider so that they overlap the bricks and nail or screw through them, but i am restoring old ones and only replacing the sills. i would be very thankful for any advice.
