I used some Wickes Fast Acting Patio Cleaner the other day to remove some stubborn and slippery grime and green algae that had accumulated in a dark, shadowy and often damp corner of the patio. It worked a treat. You apply it, scrub with a nylon brush, leave for ten minutes, then wash down. It got me wondering, if used sparingly and applied with a paint brush, whether it would be suitable for cleaning an area of ingrained grime (probably dirt and soot) on an area of brickwork to the rear of my early 19th century home which gentle scrubbing with soap and water has so far failed to remove. This Wickes stuff claims to be suitable for use on concrete, brick and natural stone but I suspect they don’t mean 195 year old bricks. The active ingredients do sound quite harsh but then again they only make up a small percentage of the mix. They are:-
Hydrochloric Acid - Less than 5%
C9-C11 Alcohol Ethoxylates – Less than 5%
Quaternary Coco Alkyi Methyl Amine Ethoxylate Methyl Chloride – Less than 5%
Just writing this I can feel you all cringing and I’m getting a strong premonition of you all screaming “NO WAY. DON'T DO IT”
