Richardwilliams
Hello All,
I own a very dilapidated early Georgian townhouse, which I am in the process of restoring. On the G floor, the property has an Inglenook fireplace, which I have been trying to get "operational", but keep getting smoked out ! After reading numerous articles on the subject , I am now extremely confused about what I should be doing with this and how to get this Inglenook working properly.
Here is what I have done to date;
- I have got the chimney swept. sweep said all was ok, chimney was in good nick and had decent draw.
- I lit fire. Lots of smoke in the room. The smoke just sat there and didn't draw up the chimney - see photo R3 of smoke just "siting there".
- Sweep suggested heating chimney, raising fire and getting fire hot. I did this, but Lots of smoke again, no draw. Fail
- I bought a canopy off ebay and fitted into the chimney. The situation improved , but there was still lots of smoke going around the canopy, and into the room - see photo R2 of the smoke coming round the canopy. (Now - when I hooked up the canopy, I did not fit it into the register plate, there was a gap between the top of the chimney hood and the register plate (gap of about 300mm) - attached in R4. The reason for this was I did not have anything to seal it with)....Is this the problem ?
My thoughts -
a) If I connect the register plate into the top of the canopy using a fabricated aluminium duct, the chimney will be sealed against the canopy, and thus creating neg pressure in canopy and improve draw and prevent smoke going up and around the canopy, thus reduce smoke in my room. ? (?It will cost me a fair bit to get a duct fabricated , and a fair bit of my time hooking it all up, does anyone have any bright ideas of a material I could use as a temporary measure to seal between canopy and register plate to test it ? If it works, I obviously don't mind spending the time / money. )
b) OR will sealing it be a waste of time, as the 200mm duct will go into the large chimney diameter after the register plate, and hit a void / cold air and not draw, with my only option being to install a flue liner all the way up ? (which I don't really want to do)
c) What did the georgians do ? presumably they did not sit in thick black smoke..or would stoves / ranges usually be in the inglenook . ( the rest of the houses fireplaces are much smaller)
Does anyone have any practical experience of this, and can offer any words of wisdom ?
Any ideas or comments would be much appreciated.
Richard
My thoughts -
Richard
