Flyfisher
- Norfolk, UK
I'm looking for a vacuum cleaner, or similar device, that I can use to clean out our attics. Not just the usual dust but loads of small bits of lime mortar that has fallen from the reed lining plus the usual small animal detritus etc etc.
I have an old vax that does a good job, but only until the filter clogs with dust, which is before the tub is half full, so I'm spending more time cleaning the filter than cleaning the attic.
I don't even need to collect the stuff; I'm quite happy to use a long hose and just eject it all into a big bin or similar. I guess I'm looking for an 'air equivalent' of a water trash pump.
I found this unit, which looks like the sort of thing I'm after, but their technical support people were not sure about overloading the motor if the 100mm hose was reduced down to something like a normal vacuum cleaner hose.
I might still give it a try but thought I'd ask here first. Any other ideas?
