DaveBrigg
- North Lincs
Our lounge wall has a damp problem. It's lime plastered and painted in breathable clay paint, but on a section 8ft wide and up to 3ft from the floor the paint is falling off, along with small patches of the top coat of plaster. This matches almost exactly with the raised floor of the room on the other side of the wall. It was a pantry, which for reasons unknown has a brick floor a foot and a half above all the other floor levels. To make things worse, on the wall in question there is a brick platform which increases the 'ground level' by another foot. The pantry floor is laid on sand, which presumably sits straight on the soil, as the outside walls have no foundations. I have already dug a French drain along the outside wall, but after nearly a year the problm remains.
As far as I can see, there are only three options.
a) Lower the floor level in the pantry and remove the brick platform. I don't think the CO would be too keen on this, and it would put the sink and window at shoulder height.
b) Keep repainting the affected area every couple of months (more often if we have visitors)
c) Buy the world's biggest flat screen TV and forget about the wall completely.
Any other ideas very gratefully received.
