A
Anonymous
Guest
Hi there
When I needed the front of my timber-framed house completely replastered in lime, a local "specialist" insisted on supplying moderately hydraulic St Astier. As a result the whole thing was done in that using a three coat system. At the time I did not know about lime putty.
The work looks very nice but the plaster is absolutely rock hard and limewash won't adhere to it properly. I have since read that Hydraulic limes have no real place in conservation work unless you're restoring a harbour wall for example.
Pretty much all the well known lime suppliers stock Hydraulic limes and I wonder how much of it is being used incorrectly, ie instead of putty.
As far as my house goes, one small crack has already appeared in the plaster and I suppose over the years I will replace blown areas with softer non-hydraulic mixes. I just hope that damp will not cause a problem in the meantime.
Any comments anyone?
Don
Don
