Antwerpman
- Antwerp,Belgium
I am currently restoring the original oak windows in my period property here in Belgium. Unfortunately conservation does not seem to have taken off in this part of the world and the usual modus operandi is to rip all the old stuff out and replace with new
Anyway one concession I have to make is to install double galzed units in to the original frames as they are very large windows (original wavy glass all gone except in a couple of small areas) and the heating bill for the house is rather large.
there is plently of depth to the original frames to rout out the recess for the panes deeper to allow for the DG units, but I havea couple of questions.
thanks in Advance for the help
- What are the common combinations of glass thickness/air gap for DG units?
I have heard that where noise supression is a requirement to use laminated glass for one of the panes, is this true and if we used this what would the thickness combinations then be?
what is the 'normal' way for mounting DG units in to wooden frames, considering that they will be treated with linseed oil and painted with Linseed oil paint. Holkam say that the oil can cause the seals on DG units to fail - how do you prevent this?Are the panes dry mounted and held in place with a bead or is putty the best method?
How much deeper does the rebate need to be than the DG units? by this I mean if the DG unit is 20mm thick, does the rebate need to be 25mm? 30mm?
