In process of buying 1920's detached house.
Original part of house has suspended wooden ground floor, 20 year old extensions on south and east sides are solid floor, leaving 4 airbricks on North wall and 2 on west wall to provide ventillation under original floor.
Following full structural survey, Surveyor's advice is to make the rest of the ground floor solid as well as he doesn't see any other way of emoving rick of dryrot developing (and of course he can't rule it out being present and there's no easy access to allow inspection)- don't really want to do his on grounds on cost and disruption - and reckon that its overkill as well.
Current state of underfloor timbers cannot be inspected at present, but there is no real flex in the wood floor.
Should ventilation on two adjacent sides be sufficient - is there a risk of a large area with little or no movement?
If so - does anyone have ant experience of pumping air under the floor to maintain air movement - thought is to pump air into the South East corner, "positively pressurizing the underfloor area forcing air to exit via airbricks in North and West walls - or any better ideas?
thanks
Charlie
thanks
Charlie
