Hello, I'm new to this forum and I want to ask a question that I'm sure will have been asked before, for which I apologise in advance. I have looked at the previous posts relating to damp basements but I think I need to ask a more basic question than the ones I've seen posted here, being really new to this and having no technical expertise.
I have a basement in the front half of my house. It has a floor of fairly worn brick laid onto earth. The basement walls are painted white but I don't know how I can tell if its a breathable paint or not. There is one window that opens just below street level at the front of the basement. At the back of the house, where there is no basement, there's a cavity of about 9 inches between the solid earth and the floorboards of the room above. There's one air brick here and I keep the door to the basement open often to increase the ventilation. But - it's still too damp in the basement for it be used.
My question is - the bricks in the floor are covered with the grime of years. If that layer of grime is removed, I don't quite know how yet, and if the walls are stripped of paint that isn't breathable - and if the ventilation can be improved, is it likely that the basement will become sufficiently dry to be useable for storage. I'm in a little terrace of 1870s houses, most of which have already had their basements tanked, but we've recently been listed and I've been told that's not now an option, added to which I would much rather sort the situation out more naturally if I can.
If that might be a solution and anyone can give me an idea of how you get rid of the layer of grime I reckon is sure to be stopping the brick floor breathing, I would be really grateful. Short of scrubbing each brick with a wire brush, I have no ideas. I think it's only years of dirt that I need to get rid of.
I think I might also benefit from having more airbricks at the back of the house so that there is better airflow.
I apologise that this is rather a basic question!
Many thanks for any help anyone can give.
Columbus
Columbus
