tractorman
- Blackmore Vale
I have principally a 16th Century cruck frame building which over the years has had the frame either stone filled or the walls replaced with stone, however, my problem is an 18th Century stone walled added wing which is cut into sloping ground to the extent of being at a maximum 18" below the external ground level, Additional this wing and all of the North, East and South faces now have a profiled concrete render at ground level to act as a "gutter" for rain spill from the thatch. Not surprisingly I have a damp wall situation.
some internal faces of external walls have received a waterproof render up to 3 ft above floor level, but the wall above the render line is considerably damp
I am proposing to remove the "gutter" and dig a French drain around the perimeter of the house, hopefully some 9" below the internal floor level. There are suitable drains lower than the trench base to discharge into. I would also use a permeable membrane between the drain and soil to resist clogging the French drain fill.
Do you see any problems with this line of attack
