Penners
- Suffolk, England
I imagine most people have read the horrific press reports of the baby scalded to death due to a failed immersion heater thermostat. A terrible business.
I thought it was worth raising here, because a substantial number of period properties have probably got the type of water heating system that caused this disaster. That is, a vented system with a header tank in the attic, and a hot water cylinder with an immersion heater.
If you have this type of system, then the potential (however remote) for this same problem to occur may exist.
The immersion heater is controlled by a thermostat. If this fails, and if the immersion heater has no overheat cutout, then the water in the cylinder can carry on being heated until it boils. The boiling water can then migrate up the vent pipe and empty itself into the header tank, which just goes on getting hotter and hotter. If the header tank eventually fails, then scalding hot water can cascade down into the house.
I don't to be alarmist about this - it's an extremely rare occurrence. And it can only happen if the immersion heater is not fitted with an overheat cutout. But since period properties are possibly more likely to have old-fashioned systems and equipment, I felt it was worth mentioning.
However remote the risk, I reckon it's worth checking your immersion heater (or if you're not familiar with the equipment, having it checked by a plumber) to make sure that yours does have a cutout.
I do have one question for any electrical/plumbing experts who read this: if the immersion heater is not fitted with an overheat cutout, is fitting a new immersion heater the only solution? Or is there such a thing as a fail-safe thermostat that will do the same job?
