worms
- ultima Thule
My immersion heater thermostat has blown, which should be an easy fix. However the eejit plumber who installed it sited the cylinder with the immersion heater round the back (which, to be fair, suits the pipe runs) and then mounted the header tank immediately above it. This causes two problems: I am working mainly by feel or with a mirror; and there is insufficient vertical space to withdraw the rod from the cylinder (so I don’t even know what the length of the current one is!).
In a previous house overseas, with two cylinders, each with two thermostats, I was constantly replacing thermostats. But back then, it was only the thermostat head itself that I was buying, not the whole fitting with the metal rod. Does anyone know if this is still an option on newer thermostats? It would save me draining and disconnecting my 92 litre header tank!
