DampedOut
TL;DR if you had to insulate a damp facade that will always see some water ingress, how would you do it?
So. This summer we had the cement facade removed from the house. The house now appears to be a 17th century Cumbrian farmhouse, then pub, then BnB, then private home. Removing the facade was a huge success—lots of beautiful character features revealed on the outside.
There's always a downside though: it faces south/south-west in Cumbria and driving rain has been pushing water in, so all the (inappropriate) internal plasterboard and gypsum has water stains now. Great.
The facade is a likely 60cm-75cm stone wall with rubble in the middle. Once the plaster in the inside comes off in the future, decisions have to be made about picking a good insulation system for a wall that will experience penetrating rain every year in autumn and probably in winter too. Water will definitely find its way in. As the climate changes, this might even get worse with more rain and less snow.
External insulation is a no-go. Conservation area + lots of beautiful revealed features on the facade, including original wooden lintels above some windows with rose head nails intact, means the facade has to stay revealed and pointed with lime.
Another limiting factor: The home owner, a relative, doesn't want to use an insulation system where the insulation has to be screwed into the solid masonry external wall and can damage the stone.
Things I've thought about but can't decide between:
1. lime plaster and calcium silicate boards sandwich—can be stuck to the wall with adhesive
2. lime plaster and wood fibre boards sandwich—probably has to be screwed in place, right?
3. hempcrete (here be dragons, right?)
Things I think are probably a bad choice:
4. solid insulating lime plaster since it's expensive to build up a layer thick enough to do significant insulating
5. battens with sheepswool in between because of condensation forming in the wall and potential for rodents
What am I missing here? How would you do it?
p.s. although I haven't posted in years, I often read on this forum and thank you to everyone here for always providing such great insights, information and advice.
