Then... once it's uploaded, shouldn't take long, your pic shoul appear in a blue backgound box. There are three things you can choose - click on the text in the bottom box (forum BB Code) and not the others.
It should go blue.
Ues the COPY (or CUT) function on your computer, then PASTE that text in the box where you do your PPUK posts.
Try the PREVIEW and see that all is OK ... then press SUBMIT.
It's pretty much the same to upload as PhotoGalaxy - use the bottom box to click on and that will copy the pic and all you need to do is paste into the PPUK post.
There is more editing which can be done, click on edit and you can resize, and you have control over the picture, which you can remove at any time.
With PhotoGalaxy the only way you can remove is by editing it out of your post I think.
There is space at the bottom of the PPUK Homepage to try it all out. Using the 'preview' button shows what you get. If you don't want then to post it you can simply click out without pressing the SUBMIT button.
Pulling my hair out with frustration here, I have goy photos uploaded onto photogalaxy, I do not understand how I get them onto the post. The I have clicked on the BBCode to the left all that does is explain how to do it.........and I having a few problems here.....................
If the pic is in a folder you may get the folder - in which case open. Click on the picture you want to upload and it should fill in the box at the bottom asking for filename. May need a double click. Click open and the whole lot should vanish and in the white box next to BROWSE on Photogalaxy you should have some writing?
Actually on my computer a double click on the pic is enough to get the white box next to browse to say where the image is stored...
