Hi all,
I've just received the structural survey for a house we are hoping to buy. I think the surveyor hs done a good job - they specialise in period houses and their report was very thorough and easy to read with photo's etc.
I dont' have any problems with any of the works they have suggested but I'd love some input from clever bods here as to likely costs, anything I should consider in a period house etc etc.
Okay details of house: 3 story mid terrace built around 1846, we're fairly sure it used to be one big building part of the weaving industry in the town. probably some time in victorian era it got divided up into tall thin houses. Its basically a rectangle with 2 rooms on each floor, the front room is 13 ft square, the back room is 9ftx7.5ft and the stairs and landing take up the other slot. The front wall is dressed stone and the back is random stone, the roof is stone slabs and was replaced around 20-30 yrs ago.
It hasn't been touched really since around 1960 - being sold after an old lady passed away so there's loads to do but these are the strucutral things commented on.
repointing of brick chimney stack
replacement of cement flashings with lead flashings
replace/overhaul cast iron gutering
repointing of stonework to front and back to include crack stitching
Timber preservation treatment and minor repairs to structural timbers, timber boarding and sub-floor timbers (evidence of woodboring attack in roof timbers and flooring)
Installing ties to front and rear walls to connect to floor and party wall (this isn't urgent, more of a precuation because he said the house didn't appear to have standard lateral restraint due to arrangement of beams and joists)
Now there's two I'm less sure about,
Damp - when we looked round the house (which has been vacant for over a year with no heating) it felt VERY dry and warm - tbh it felt dryer than OUR house!
I'm personally of the opinion that once we repoint, sort out guttering etc we wont' have that much of a damp problem if any. Especially as the report says that alot of damp round windows is caused by rainwater penetration.
However the report also says "the ground floor walls are all experiencing rising damp" is this likely? it honestly didn't feel damp but is there anything else I can do to check it out further. As far as I can remember and see from the photo's we took and surveyor took the exterior groudn level is below the floor level but I'm not sure about ventilation bricks etc.
All the moment all the walls have multiple layers of wallpaper etc, we were planning on stripping it right back (and doing any additional wiring/radiator fitting etc) then replastering. Is it possible the 'rising damp' is simply rainwater penetration combined with unbreathable wall coverings?
Kitchen floor which surveyor thinks is flags onto earth there were very high moisture readings on kitchen floor (yes I know moisture readings are a load of b*******.
If it is then he recomends we take 'em up, excavate underneath, lay a new concrete floor inc dampproof membrane etc and then relay flags - so.....
do we need to do this? whats the likely cost? is there an easier/cheaper alternative? how do I find out if it really is damp?
I was actually hoping to put down a new solid wood floor throughout th open plan ground floor - is this still possible if its on top of concrete/earth.
The 'kitchen' is a small 1950's extension actually and we've already chatted to the conservation officer about taking it down and replacing it with something a bit more sympathetic (and ever so slightly larger - like the next door one!). If we're going to do this do we just ignore the floor and get costs for the new extension?
Come to that I know its a daft question in one way but anyone any ideas or experience of costs for a 6ftx8ft single story extension, have to be in stone or yellow brick with a pitched tiled roofline.
Sorry if this all sounds a bit niave, happy to do whatever research and additional surveys might be needed. We are taking it on as a renovation project so are prepared for a fair bit of work. Its our first listed house but we've been doing up and living in a late edwardian house for the past 10 years.
