I've finally realised that high or sub-optimal external ground level seems to be a culprit and easy to fix source of internal damp issue.
Therefore, ideally how many cm below internal finished floor level should the external ground be in in-order to avoid and rising damp/internal damp issues from external grounds? i.e. is there a minimum threshold?
Thank you
Thank you
