AndrewB
- Northern Ireland
Hey guys,
Ive been doing some repairs and improving drainage along the side of my property. I've been in contact with some builders and plastered and frankly give up. Can't get anyone to do the job. I usually take on most things but previously drew the line at plaster and bricks... Guess I'm going to have to do it myself!
The level of the drive was way too high so going to tidy it all up and add a French drain.
Anyway, my question is about the brick plinth (think that's the name). As you can see, it's in bad shape in a few areas. The bricks which used to stick out are completly crumbled away at the front of the house. Those that remain 'under the wall' are crumbly and cracked also.
I'm wondering; can I make some sort of lime mortor and remake the plinth with layers of mortor? If so, what would the recipie for the mix be?
Do I need to replace the bricks first by digging out the old ones? If so, what would the recipie for the mortor between the bricks be? (same as the 'render'?). But scared of removing bricks! Any advice appreciated!
I just has another area repaired by a proper Brickie, so have half a bag of nhl 3.5 and 3 bags of plastering sand at the moment.
Thanks for the help!
