briany
- Waterford, Ireland
The hearth is about 1.5 inches thick, and is made of one lovely limestone slab. I've seen a number of other solid hearths that have split and pushed apart from the heat. I know one solution is to slice'n'dice it up and reset the portions so they can expand and contract independently, but I really don't want to chop up that nice slab if I can possibly figure out a dodge.
I'm installing a large stove in, or rather in front, of the fireplace, and it will sit squarely on top of the slab. The heat radiated downwards will inevitably cause the slab to crack due to the difference in thermal expansion between the centre of the slab and the edges unless I can insulate the slab centre somehow...
Does anyone know of a solid, fireproof, insulating material that could take the weight of a substantial woodstove (120-odd kg)?
Would mounting the stove on a layer of clay bricks or tiles work? A thick sheet of mica-like material, if such a thing existed, might do the trick. Or a layer of those tiles that fall off the space shuttle on a regular basis.
Thanks in advance for any ideas.
Brian
Brian
