My end of terrace whinstone 1870's house is built into a hillside, near the top. The ground floor is completely underground on the northwest side, with a tarmaced road immediately adjacent, and the gable end has a set of public steps running down immediately adjacent. No possibility of lowering ground levels. The house was renovated in the 60's when I assume the cavity brick wall was added on the two walls which are fully/partially underground, and the joists sit on dwarf brick walls on a wooden plinth.
I am experiencing some damp in the corner that is completely underground, some salts are depositing on the internal cement plaster, which seems to attract moisture from cooking etc. joists are good under floor, though ground below is cold/damp to touch in that corner as well, and bricks and wall very cold/damp to touch there also.
having redecorated recently, salts and moisture have damaged wallpaper finish a bit, and will probably have to redecorate in a couple of years, probably replacing cement plaster with lime plaster on those walls. However, I wonder if there is rubble between the solid and cavity walls and causing bridging. (pointing outside on gable end needs redone)How do I investigate this, and if there is rubble, how do i remove it?
