plasticpigeon
- Birmingham
This might seem a daft question, but I can't see how to do this neatly with plastic pipe. i can buy a 90 degree elbow with a socket on both ends or a socket on one end. However if i Have a 90 deg bend with a socket butting up to the wall joining the pipe that comes out of the back of the pan the pipe tha runs parallel to the wall is too far from the wall. What I want is a 110mm 90 degree sweep so that I can cut the pipe to length so that it can go through the wall and join to the back of the pan and curve as soon as it exits the outside wall, but this isn't made. I don't want to make a bigger hole in the brick wall to accomodate a socket. What can be done??
