Zebra
- St Albans, Hertfordshire
I have some inch thick tongue-and-groove oak flooring to lay. The floor is an insulated concrete one, but with no screed. I've decided if I can, to lay the floor over timbers directly onto the concrete, rather than screeding, mainly because then I can do it myself. Central heating pipes will go in the gap under the boards.
There seem to be two methods of fixing timber floors which I've come across. One is the suspended floor - boards over joists sitting in hangers or resting on dwarf walls. The other method is the floating floor, where boards are attached to timbers laid directly onto the concrete but not fixed to it.
I've never come across one where the boards are fixed to timbers laid onto the concrete and bolted down to it. Why would this be? It would seem to be a good solution in this situation. I know how thick the concrete is, so won't drill into the dpc. Do the timbers need to expand and contract, which would be prevented if they were bolted down?
Many thanks for help and tips!
