88v8
- Glorious Gloucs
I've always glued by applying to a clean dust-free joint and cramping up pronto.
However, when looking for some fresh Cascophen (then called Extraphen and now called Polyproof - why?) I found this description of how to glue:
DIRECTIONS FOR USE
To obtain the very best results the moisture content should be in the 12-14% range.
Timber bought as kiln dried and stored under cover will present no problem.
Perhaps as important as the glue is the preparation the joining surfaces, especially for Oak and oily timbers, Teak, Iroko etc.
Timber direct from machining has a slightly glazed surface and the surface fibres are compressed by rollers etc, far from ideal and it is essential that the surfaces to be joined should be ridded of this unwanted smoothness.
Use a scouring plane (blade with fine points), hacksaw blade, or very coarse sandpaper. Plywood must be treated in the same manner.
The gluing area should be abraded as close to bonding time as practically possible.
Dust with a bristle brush, oily timbers should be degreased with methylated spirit.
As important as preparation, is working in the correct temperature and that means, within reason, as warm as possible, 20C is ideal. At higher temperatures the glue becomes much less viscous, easier to apply and penetrates the timber instead of laying on the surface, a better glue line results.
For the best results both surfaces of the joint should be glued. Use good quality brushes. Surfaces once glued should not be exposed to the air for any length of time.
Do not over cramp; it’s possible to starve a joint this way. A minimum of twenty minutes closed assembly time should be allowed before the application of pressure.
Just bring the surfaces firmly into contact.
This will enable the glue to penetrate the surface fibres of the timber and avoid excessive squeeze-out.
Who knew?
I have to glue a drip-bar onto my garage door.
It's certainly not 70F out there. Need to close the doors and heat up the space. Oh, no doors. Doomed.
Ivor
DIRECTIONS FOR USE
Who knew?
Ivor
