Hi
I have a large hole in my hallway floorboards right behind the froontdoor where I'm assuming a recessed doormat used to be installed. At the moment the hole is covered by an unsuitable and flexible piece of wood and I have no room between the floor and the bottom pf the door to lay a loose mat.
I would like to replace this arrangement with a proper recessed doormat and would like to know the best way of doing this.
There is quite a large space underneat the floorboards so I obviously need a safe and secure means of doing this that will not flex or fail.
Thanks for your advice
Matthew
Matthew
