I have discovered a significant and cold draught at floor board level around the chimney breast of an upstairs bedroom and am after some advice on how to best deal with it.
The chimney originally served this room and the room below however it no longer serves either. The entire chimney breast has been removed from the lower room, the chimney stack has been removed just below the roof line and although the original cast iron fireplace still exists in the bedroom the damper flap has been removed and sealed (with plaster by the looks of it). I suspect the chimney flue which served the down stairs room has been left open below the bedroom floor boards and the draught is coming from the cold loft space into the void between the down stairs ceiling and upstairs floor. Both these rooms are significantly colder than the rest of the house.
My thinking is to simply block off/seal the redundant chimney in the loft (which would be a lot easier than doing anything at the chimney bottom). Is it this simple or is some sort of ventilation for the chimney still required?
Thanks in advance
Thanks in advance
