Any ideas on how to remove and replace a rotten timber lintel without the brickwork above falling down?
The lintel in question is above an outside door at one end of a 9”thick gable wall.
There is an arched brickwork lintel above the door on the outside face of the wall but just a straight piece of 4X4 timber on the inside face which is rotten to the core. I’ve pulled away some of the rotten timber only to find that the brickwork above (at least one or two courses) is loose allowing pieces of mortar to fall away.
Due to the fact that the door is located at one end of the gable wall, there is not a huge amount of brickwork above, probably a maximum of about 10 courses before reaching the pitch of the roof.
I have discovered this problem having just removed a section of water damaged lath plaster ceiling. The ceiling joists all appear to very sound however they run parallel to the gable wall, the first joist being only 3 or 4 inches away from the wall which would make it very difficult to incorporate acro props etc.
Any suggestions on how to rectify this problem without too much disruption would be appreciated
