victrc
- Macclesfield
I’m a FTB in England with an offer accepted on a Grade II Victorian mid-terrace that’s also in a conservation area.
I’ve just had a L3 survey done and while I was expecting some of the issues that were raised (e.g. high damp readings), the overall opinion section states that “The property cannot be considered to be a reasonable purchase as there are a number of defects that require immediate attention, such as an assessment of the first floor [note - this is in relation to excessive movement on a heel-drop test, likely due to “the floor not being supported property or weakened by a timber defect”] which will require some expenditure at the outset. I would not expect any particular difficulty on resale in normal market conditions, provided that the necessary works are carried out to a satisfactory standard.”
However, when I spoke to him after receiving the survey, he didn’t seem too concerned and said that he’d seen worse in other properties and that it was a lovely house.
So I’m a bit unsure how to proceed - I was already nervous about buying a listed building as a first property, and I did find the survey quite worrying (not just the floor issue, there was also a small gap between fitted boards in the roof space and 6 sash windows that couldn’t be opened and would need repair or replacement, which obviously has the potential to be very expensive). I do know it’s to be expected that a lot of issues will come up on a survey for an older house! I’m just not sure whether this is actually fairly standard or whether, given that the surveyor said that it isn’t a reasonable purchase, I should be looking to withdraw the offer before even getting the necessary specialist surveys and quotes.
I know a lot of people just advise not to buy a listed building in the first place so was hoping to get some slightly more balanced views here - thanks!
