Tom
- Charente, France
Following a slight clean up (well overdue!), it's come to light that we need to fill in the gaps between the flags on the floor. However, the gaps are very small so I'm unsure how to do this and I'm not sure what to use. The floor is breathable (LECA / Limecrete with wet UFH) but, as yet, the flags are untreated. I had planned to treat them with Holkham's Linseed Oil, as recommended on here.
My builder suggested brushing a dry mix of sand and Lime 3:1 over the floor until the gaps were filled, then water the lot and leave to go off. This makes sense but I'm worried that dry Lime will stain the flags. Likewise, I'm worried that a wet mix will stain them, although I can't see how we'd even get a wet mix in the gaps.
is there a way I can fill these gaps before I oil the floor or would it be better to oil the floor first...but then what?
Here's what we're dealing with....
