Can anybody suggest the best way to clean old brick work (about 190 years old) One elevation of my property has a two tone colour scheme of predominately red brickwork with about six courses of yellow brick up from the ground, yellow brick edging on the corners of the property and yellow brick arches over the windows.
Unfortunately much of the clarity and richness of this detailing has been lost to the grime that has caked itself onto the surface over the years. I suspect that this grime is old soot deposits combined with sea salt as I live near the coast and not in a particularly built up or traffic congested area.
Obviously I don’t want to use anything to harsh on these old bricks so I want to avoid sand blasting. I’m even wary of using chemicals.
Once when I hired out a power washer to clean a pathway, I experimented by aiming the washer at a particularly dark patch on the wall just for a few seconds. It made the wall very wet but didn’t budge the grime. In any case I think too longer blasting with a power washer could over saturate the bricks and even dislodge the pointing. Any other suggestions for returning this old brickwork to its former glory would be appreciated.
