I have had two roofs re slated in the last two years and took the opportunity to have the roofs covered with a modern breathable membrane prior to the fixing of battens and slates. Apparently this membrane acts a bit like “Gortex” i.e. it allows air to permeate through freely but stops rainwater coming in.
The old slates were unfortunately unsalvageable having been turnerised (covered with hessian and tar) some years ago. These old slates had no roofing felt underneath them, just fixed directly onto the battens and sealed up with what I think they call torching, clumps of lime mortar between the batten and the slate.
One of the roof voids has gable ventilation grilles at each end and so there is plenty of ventilation through the void. The other roof void however has no ventilation other than a few holes drilled in the access hatch at one end allowing a limited amount of air to pass up into the void from the room below. Both voids have been insulated with rolled fibre blanket laid between the ceiling joists.
Will the new breathable membrane be providing sufficient ventilation to the latter roof void which has no ventilation grilles?
