skier-hughes
- Staffs, UK
So today, being a dry day I thought I'd do some work outside!!!!
To be thwarted by some ominous looking bubbles which appeared overnight in the bathroom ceiling paintwork.
I thought I'd better investigate......
A bucketful of water later and the slow pour becomes a drip.
About an 8' sqaure of paint is easily removed, being modern stuff as it just peeled off in big patches.
Having just removed the scaffolding from when we rebuilt the chimney I thought something had got damaged as it came down, so up into the loft and I inspected as best I could, but I just couldn;t find any sign of wetness indicating a leak anywhere.
Came down for a rest.
Back up and started to remove the insulation from around the water tank, and....... yep, I found the water as the insulation was wringing wet. The ball valve wasn't quite sitting right, it kept dripping water in, which kept dripping out of the overflow pipe which wasn't quite fitted correctly in the tank, so for how many years I don't know this water has been dripping into the loft.
I've removed all the wet insulation, I've dried the plasterboard the best I can, I've sorted the ball valve and refitted the overflow pipe so even if it shuld be needed it shouldn't leak again.
The problem though is the wood is absolutely saturated, so much so it is spongy.
I've checked how far this goes, (not too far in) as the weight of the tank is obviously coming into play here, don't want all of that in the bathroom!!!
Do I put an electric heater up there? A dehumidifier - means buying one, so what would be recommended? just leave it to see if the natural air flow dries it out when it warms up gain this summer
Should I remove the sodden plaster board? I don't really want to, as I'm trying to do the kitchen and although the bathroom is next on the list, I don't want to be doing two things at once, but I'm willing to do this if it means the wood will dry lots quicker and it'd be better for that.
I could call the insurers and see if they'll pay out :wink:
