charlie-ia
- LANCASHIRE
chuckey said:Around here the downhill wall quite often falls out of buildings( well after 300 years or so). Its particularily common when the ridge is running parrallel to the slope. Its is caused by the weight of the roof pushing the walls out as there is only one truss holding the front wall to the back wall. And of course by the rubbish foundations!
What the old timers did when they built my cottage (pre-1805) was to dig a trench over 24" deep, hurl in the biggest stones they could find, then build the walls on these. The problem is that they never filled the voids in and around these "foundation" stones, so over the years the action of water and the weight of the walls cause the soil to move into these voids and the building to settle. I discovered this when poking about to see if the building had a stepped foundation, and after about 6" of topsoil, my spike often dropped 2 feet into a void. if any one has a cure for this problem I too will be grateful.
I did french drains around my place working on the asumption that it is safe to dig down to 6" below the original floor level then if you want to go deeper, outwards at 45 degrees. As I reckon my foundation stones extend for 18" deeper then my drain level I think the building is secure.
Frank
