rebeccac
- Cornwall/Italy
Well it seemed too good to be true - we've dug out a French drain at the back of the house , dug out the floor in the sitting room , chipped off acres of cement from inside the kitchen and just when it seemed that we might almost be ready to start on the kitchen plastering we found this!
In 2 corners of the room there appears to be big holes that have been filled in with earth instead of stone!
It's clay and its very wet so now we have no cement over it the water is coming out onto the edges of the brick floor.We cannot imagine why we have found these earth filled holes but both are at the base of what was originally a stone archway of a church ( our house was once opart of a small church but it was turned into a house about 100 years ago.) We think that possibly there was a stone feature in the corners and that was taken out when the dividing wall was constructed and the holes filled with earth ?
Anyway we now think we should take up the enitre floor and re-lay it onto a limecrete base so its about 10 cms higher we can then fit in a french drain that goes out through the wall to take water from these 2 wet areas away from the walls/floors.
Another factor is the dividing wall has no foundations so we cannot dig down in case we undermine it!
Any suggestions?
As the picture shows we have removed the bricks from around the edges of the room ( to re-lay) and the earth I mention is in the wall not just on the floor covereing an area of about 1ft x 1ft.
Any suggestions?
