blue-round-the-edges
I'm sure other people must have this problem, but couldn't find a link with search, or looking quite a way down the list of topics.
I live in a timber framed house, originally labourers' cottages. It has a rubble base and lath and plaster and brick in filling with a thatch. The latch and plaster ceiling does not have a loft hatch. Despite heating my nursery thermometer has registered 10 degrees for much of Jan in my bedroom- it doesn't go any lower than this! The walls are v thin, but also there are gaps (you can see light!) and big draughts between timber frame and in filling and also where roof beams hit the walls.
I now have an electric blanket & big duvet for the bed, jumpers, woolly hat and down jacket for all other times. I even have a blanket to sit under on the sofa (required on many evenings this winter!). Never-the-less it's been b***y chilly and getting dressed is traumatic to say the least.
Questions are:
How best to plug the holes. There are quite big ones under the thatch eves which we have filled with bits of fibre glass insulation roll as an emergency measure. Also can we put in internal wall insulation? I know that this can be prone to problems with damp, but we really don't have a problem with adequate ventilation at present! Thought about wool fleece and dry lining, even if this does cover up some beams - there are plenty so a few missing would be Ok with us, but not sure about LBC. Someone also suggested rendering over everything including frame outside with thicker lime mortar, as the building would probably not have had exposed timbers externally originally.
Hoping to have a good 8 months before a solution is really necessary!
thank you for your advice.
Questions are:
