Have bought part of a victorian pile and have now discovered there is a large tank in the ground (3 feet from the building) out the back. It is approximately 8 ft across and 12 -14 ft deep perfectly round with a flat bottom and domed top- it obviously collected rainwater for use in the house / garden in years gone by; it has an overflow and a steel pipe which was presumably connected to a pump. at aquess it has been there for 100 / 150 years.
Question for all you knowledgable ones - do I have to fill it before I biuld a raised deck / terrace above it? or, could I plug the top and then cast a reinforced plinth right across the site as the foundationd for the terrace?
All thoughts greatfully received
HG
HG
