TimHardusty
- Portland, Dorset
We have just started to rework the kitchen in our 17th century Portland stone G2 listed cottage. There's a relatively recent (in the context of the house's age!) extension at the back made from smooth blocks of some description - possibly Portland stone, with a doorway to it from the main (original) sitting room.
The main ground floor walls of the house are about 1m thick, and the upstairs walls maybe half that. There are a couple of steps up from the sitting room to the kitchen, with some cladding covering everything: much of the cladding came off yesterday to reveal the (lack of?) construction when the door way was made This was probably done at least 100 years ago, but reworked since I think).
Here is a picture to put it in context:
The wall behind where the microwave is perched is about 100mm thick (can't see the type of block) and the beam top right runs to the front of the house, through the sitting room, and supports floors etc. upstairs. To have one end resting on a thin block wall is my first concern - is it beefy enough?
The vertical wooden support rests on an elderly log:
but I can't see what it's supporting as the "ceiling" in that area is a mix of newspaper, stone, rubble and mortar of somer sort.
You can also see in that picture that although there is a sturdy block pillar sort-of supporting the thinner upstairs wall (the wall is the part that has the wooden battening on it) there is nothing running left/right to support the wall. The front/back huge timber doesn't look like it has been cut at all but who knows.
So, the million dollar question is whether a span like that of upstairs ancient portland stone can be self supporting (he hopes, naively) or whether we need to get this inspected and, probably, sorted with some form of timber or RSJ or whatever.
Opinions and thoughts welcomed!
