Stonehouse
- United Kingdom
Good morning all
Is anyone else struggling with high humidity?
I did a post a while back as we had Mdf skirting fitted to our St Astier plaster. I put lime plaster between skirting and wall to fill the gaps. I now wish I had used caulk. We have green mould growing under the skirting in some areas. I’m not sure if it is from damp walls or if I’ve trapped moisture behind which is taking a long time to dry out (we’re about 4 weeks now) or decorating. We’re lime outside.
I’m constantly opening windows and started to run a dehumidifier in evenings as the humidity is 70-80% in the room/corners where green mould is. It’s so frustrating!
If anyone else has any tips or ideas please may you share! Thank you so much
