I know this has been mentioned often in the past on here but I'm interested in experimenting with hemp lime plaster on the interior of our exterior walls to try and add some insulation/thermal mass. Having removed cement render from the bottom half of these walls we are left with bare stone ready for replastering and wonder if the addition of hemp really does give any benefit over lime and sand alone.
I'm aware of the basic idea involved but wondered if anyone has any practical experience of using it as a plaster?
What lime is best to use, what ratios is the best mix, have you noticed any improvement in thermal efficency, how thickly did you apply it? How many coats?
Also where Is the best value source of hemp? Will the shiv used for horse bedding work for rough work/ base layers? I'm not really interested in pre mixed commercial solutions with additives etc as they are so over priced.
I know there is much hemp cultivated in the Yorkshire area and I've been in touch with a couple of farms already but does anyone have any recommendations?
Ultimately is the cost worth the effort against the benefits?
Any advice, ideas or opinions would be greatly appreciated!
